Popup Shutdown and Auto Poweroff
My 13" MacBook Pro is just over a year and the problem occurred 2 weeks ago.
At first, it suddenly showed message "Are you sure you want to shutdown your computer?" shortly after the machine started. It kept showing the message after 20+ seconds even the "Cancel" button was clicked, as if someone has clicked the power button.
A hardware test was performed with the original disk and no problem found. It was then tried the "Erase and Install" but it halted and shutdown when it started the installation.
From then on, the machine is hard to power up, sometimes it can power up and sometimes not.
I brought it to the service center the staff there told me the logic board is probably had problem with water. But It had been using properly and was not spilled with water as far as I can remember.
Anyone know the reason or had similar experience please help.
KLO
この質問は役に立ちましたか?
