メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
締切られた回答
LCD/Digitizer not working but same assembly will work in another phone
I'm a bit stumped on this... My wife's phone is completely working except for the LCD/Digitizer. I am able to make calls using her cars bluetooth system and phone is visible in iTunes. I'm and very proficient in electronics repair.
I thought it was just the LCD randomly messing up, but I tried using my iPhone 6's front assembly and it didn't work. So, I hooked up the seemingly broken LCD/Digitizer to my phone and it works fine. There is a faint glow coming from the LCD.
I'm left with, somehow my wife's iPhone connector or LCD filters is broken? I don't know where to begin to troubleshoot this. Is there any way for me to get the data off her phone? The home button works, but I have no way of entering the passcode...
Do you think Apple will fix this under warranty?
Thanks for any help!!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
If the phone is still under warranty and doesn't show signs of abuse, Apple would be a good start.
There is a control chip on the mainboard of the phone that could have gone bad. I lean more towards the simple answer which would be an issue with the connector. Try cleaning the connector on the phone with 99% alcohol (please unplug the battery first) and clean the digi connector at the same time. Once you get the phone back together, hold power and volume together a few times and see if the digi starts working. If that doesn't get it going, I would take it to a reputable repair shop in your area.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I cleaned the connectors and got some white blocks on part of the screen for ~1min but then the same problem still. Probably going to see Apple about repair.
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 95
