メインコンテンツにスキップ
食器洗浄機の修理と解体ガイド
705回答 すべてを表示
Maytag dishwasher MDB-3 fills, runs a few seconds, then stops.
This unit fills properly, then runs maybe 3 seconds, then stops.
After opening, unit has water in tub (it should).
Hitting start/cancel causes unit to drain properly.
After opening, unit is dry (it should be).
Can find no obvious blockages.
Motor works, pump works, etc. The machines is 13 yrs. old but runs very well. Don't want a new one. Thanks you!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
最も参考になった回答
Door Lock Motor and Switch Assembly
The door lock secures the washer door shut during operation. Once the washer door is closed, the washer can begin operating. If the washer door is not latched shut, the door switch will prevent the washer from operating. If the door lock is defective, the washer will not spin or start. The door lock can fail either mechanically or electrically. Inspect the door lock for damage. If the door lock is damaged or does not latch properly, replace it. To determine if the door lock has failed electrically, consult your washer’s wiring diagram and use a multimeter to test each of the door lock switches for continuity. If one of the switches does not have continuity, replace the switch.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Door lock is okay. Washer runs maybe 10 seconds then stops.
さんによる
コメントを追加
回答を追加する
gdmagnin2 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 3,533
