メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Home key broken of ribbon
Hi everybody. I have an iphone 6 with broken home button. As I've read that missing original home button leads to error while update I'm interested in one thing. In my case only the button is broken of the little ribbon and ribbon is still in place with its little chip in the middle on ribbon. So my question is will this ribbon connected be enough not to take my phone to error state. This may be a stupid question since I'm no tehnicion but the ribbon has a chip in the middle of it and I'm wondering is that enough not to get stuck with error while doing an update.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
There is no chip on the ribbon, just a few passive components. In order for this to work, you need the chip inside the button.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
I know you have a lot of answers, but ah.. You sure about that?
さんによる
Yes. There is a chip on iPhone 5s, but not on iPhone 6 home button ribbon cable. Even if there is a separate chip, no one can guarantee it can work, the chips could be coded to each other.
さんによる
コメントを追加
最も参考になった回答
i don't think so... If I were you, I'd take it to apple. See what they say. Pretty sure you won't get the error. Unless you put an aftermarket button on there
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
the same thing happened to my brother and he taped the hole with duct tape , wnet into settings and got up the home button help . hope it helps if not sorry but tried :)
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Thats what I'm doing at the moment, enabled on screen home button via accessability. Thanks for Your help but I'm interasted what happens during softweare update, such as instaling new ios update and does the update go trought without errors?
さんによる
Yes it worked fine for my bro
さんによる
コメントを追加
回答を追加する
BrZi さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 216
