メインコンテンツにスキップ
Portable wireless speakers from Logitech released in 2013.
70回答 すべてを表示
Why won't my speaker connect to my phone via Bluetooth?
My speaker is on and ready to pair, and my Bluetooth-enabled phone or tablet is searching for devices, but it cannot "find" my speaker and connect to it.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 27
23 件のコメント
Note doing a hard start deleats ALL your contacs, music, photo, ect. Before doing so save all to sd card an remove sd card. Rite down any important info such as contacts, memo, ect. You have been warned.
さんによる
My Bluetooth is on and my speaker is too but the name of my speaker won't show on my phone to connect to it what shall I do?
さんによる
My bluetooth is on my speaker is on too . It can search the name of speaker but i cant connect it it says " it cant communicate'
さんによる
Hello I had the same problem and it came successfully to connect on my iPad but I wanted to connect it to my phone if all fails try holding down the little button next to the power button and hold it down and (make sure you have your Bluetooth on) then when it makes a sound it will come up on your device immediately. I hope this helped
さんによる
I had this problem. I reset my speaker and now it is working! Thank you.
さんによる
18件以上のコメントを表示
コメントを追加
16件の回答
ベストアンサー
If your UE Boom speaker is having trouble pairing to another device via Bluetooth, see the UE Boom Bluetooth Pairing Is Not Working problem page for possible causes and solutions.
1. Try moving your speaker closer to your phone or tablet to make sure the Bluetooth is in range.
2. If your phone or tablet is connected to Wi-fi it will make the pairing more efficient
3. The UE BOOM can only connect to two devices at a time so make sure that you aren't connected to the maximum number of devices already.
4. If you have two UE BOOM speakers make sure that you are connecting to the correct one.
5. If the first 4 steps do not solve the problem try applying a factory reset to your UE BOOM.
***Hold down the power button and the volume down button for roughly 10 seconds until you hear a sound. At that point, your device will turn off. Turn it back on and try to pair it to your phone or tablet again.
Take a look at our trouble shooting page for more information and possible solutions.
UE BOOM Troubleshooting Page
このアンサーは役に立ちましたか?
スコア 46
34 件のコメント:
Thank you!!!!!!! I didn't know I could reset my speaker to factory settings. It solved the problem immediatley!!!! THANKS!
さんによる
FINALLY - figured out why my phone wouldn't pair
Auvio bluetooth speaker. My laptop was already auto-pairing and can’t have 2 devices paired at once, so my phone could never pair!! The list of things to check should maybe include "make sure other devices are not already paired."
さんによる
Agreed, the factory settings fix was immediate :) Thanks for the tips!!
さんによる
The factory reset worked. Thank you.
さんによる
Thank you! This worked for me as well with my replacement iPhone 6 plus that was not pairing with my UE Boom.
さんによる
29件以上のコメントを表示
コメントを追加
Nothing had worked of what you told us above.
Finally I found a solution:
1.Turn on your UE Boom.
2.Hold down the volume down button and the power button AT THE SAME TIME until you hear a sound. Your UE Boom will then turn off.
3.Turn it back on and try to pair it with your device again.
Finally i can see it in all phones again:)
Good luck
このアンサーは役に立ちましたか?
スコア 9
12 件のコメント:
Thank you so much...it worked...really appreciated your help
さんによる
OMG thank you it absolutely worked .......
さんによる
thank you......
さんによる
Worked!!! Thank you!!
さんによる
Fantastic buddy!!!!...thanks a lot!! :D
さんによる
7件以上のコメントを表示
コメントを追加
I found that my problem was my iPhone not the wireless speaker.
Go to settings & Bluetooth. Click on the small i next to Soundcore. Click on Forget this device. Soundcore disappears. Start pairing process again. It should link this time R.E.D. 10.6.17
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
thank you so much!! you were the only one after weeks of trying to figure out what was wrong to help me!
さんによる
This worked for me on iPhoneX! Thanks!
さんによる
You're amazing!!!! A 2 year old got hold of my speaker and i couldn't do a thing. Well done that man!
さんによる
コメントを追加
Pairing rejected by megaboom for several days...tried hard reset, all button reset, everything...wouldn't work.
Finally renamed my phone while boom reset...working great.
Hope this helps others w same problem.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
You are legendary
さんによる
UPVOTE AND PIN THIS ANSWER! IF EVERYTHING SEEMS TO FAIL , CHANGE THE NAME ON YOUR PHONE THE SPEAKER CANNNOT HAVE 2 IDENTICAL NAMED DEVICES ! - don’t thank me thank buddy above me !!!
さんによる
Thanks, changing my device name WORKED!!!
さんによる
コメントを追加
After resetting to factory settings I still can't set bluetooth my iPhone 6 to my new UE megaboom
The bluetooth light is flashing I have done all the right things as per the You Tube instructions
Please help
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
I’ve restarted it and tried connecting it again. Still not working. I have no other devices connected.
さんによる
Did you resolve your problem UE i have also same problem it is not connecting Bluetooth
さんによる
コメントを追加
Talk about being tide down. Some bluetooth devices have to be within 2 feet or less to redgister. I encountered this with my HTC Desire 526 and a bluetooth key board. To sync them i set them tite against each other, then they would work fine provided within 2 feet or less. Wireless sounds great untill you use it then it sucks. I returned my key board. I hope this helps.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
My UE boom is connecting to my friends phone so it must be my Samsung android
さんによる
コメントを追加
I bought an Auvio bluetooth speaker. My macbook / laptop was already auto-pairing, and I leave it on all the time. Guess I can’t have 2 devices paired at once, so my phone could never pair!! The list of things to check should maybe include "un-pair other devices…."
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Still won't work. Help
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Mine still won't work. Please help
さんによる
Mine will pair with my phone but not with my laptop
さんによる
コメントを追加
i have same issue. I have already used my XS Boom speaker once - now I am trying to use it again and it won't pair. After I turn the speaker on, I go to my phone and it says "Connection Unsuccessful -make sure xsboom is turned on and is in range." Ummm- I am pushing the button and getting the sound and flashing light...so it's on...and I'm def in range b/c the phone and speaker are both on my desk as I try to get it to work! I fully charged it and I did notice the light was red - which if I recall the instructions said that means it's fully charged. Help!?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
My I-phone previously showed my two UE booms as "not connected" and now neither one. I have performed the hard shut-down and with the Boom on it still does not register under bluetooth settings. Please help
さんによる
コメントを追加
Still my UE megaboom is not pairing with my phone...In my phone it just read numbers and when I try to connect it said incorrect pin..Please help.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Worked perfectly after the reset
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My problem was that two other devices were connected to my speakers already and I didn't know that they were. So, try disabling bluetooth on the devices that you aren't using.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Good luck
さんによる
コメントを追加
If anyone is reading this still in the future, having 2 phones with the same name WILL NOT WORK.
(Had my old iphone, which was still on. So my new iphone couldn't connect (MAC adress mismatch).)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have tried all Troubleshooting nothing works. The UE Boom works on other phones and I used to use it a lot on my phone but now it has stopped working. It started with "Connection Unsuccessful" tried the hard reset and repair etc. I removed the UE Boom from my paired list and now it doesnt show up at all when searching for it. I have updated the UE Boom and restarted my phone but nothing seams to fix it. I am using a Huawei M9 and its as if for some reason the phone has decided its not compatible or something. FYI my phone connects fine to other devices like my PC and my Car, just NOT the UE BOOM!!!!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I reset my megaboom.
It worked with my new gs9
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
How do you find out if your speaker Is paired to a second device and what the device might be???
さんによる
A ue roll 2 speaker that is
さんによる
コメントを追加
I have factory reset UE speaker. Then turn on . Is is blinking Bluetooth button is blinking but in my phone not showing scanning range
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
i have tried everything it connects to my hp laptop but has never once been abe to pair with my lg stylo 4 phone .. any other ideas ..factory reset done . this is a new phone so it has never been linked to it ..and like it connects to hp laptop fine but im not walking around holding my laptop right ..thanks for ideas
さんによる
コメントを追加
回答を追加する
Sean Reilly さん、ありがとうございました!
統計データ:
過去 24時間: 9
過去 7 日: 52
過去 30 日: 229
今までの合計 540,025
