メインコンテンツにスキップ
Released November 13, 2011, this is the only model ever released. It can be disassembled with screwdrivers and a small amount of prying. Model # CECH-ZED1U
9回答 すべてを表示
Why does the sound occasionally sound scratchy and thin?
While using the Sony PlayStation 3D Display, the sound occasionally sounds very thin and scratchy like there is a bad connection. What would be a way to fix this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
RE:Why does the sound occasionally sound scratchy and thin?
Poor sound quality can be caused by several issues including bad input cables, bad video/audio ports, and bad speakers. You should be able to determine the problem by trying different cables and different input ports. If this still doesn't solve the problem you may need to replace the speakers. Follow the speaker replacement guide to do so.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Logan Simon さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 5
今までの合計 345
