Why isn’t the touchscreen working?
The screen freezes and becomes unresponsive to the touch.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
This could be a simple problem with a simple fix. First make sure the device is clean and free of dirt and dust. This is the most likely reason the touchscreen isn’t functioning properly. If the device is clean and still is unresponsive, perform a touchscreen-free factory reset of the device detailed in the troubleshooting guide. If a factory reset is unsuccessful, the screen may need to be replaced. Visit this Troubleshooting Page for help with the above and more answers.
このアンサーは役に立ちましたか?
Just opened mine and none of the touch screen works
My watch screen turn white , so i dont know how to fix it
just opened mien and screen wont even work
will a factory re-set remove all of the data I've already recorded?
このアンサーは役に立ちましたか?
It honestly hurts how painfully stupid your comment is.
Be fair - sometimes a "factory reset" may not be all it seems. That has become a well-worn term that sometimes means what it says, and sometimes is a bit of a reboot flushing some - but not all - data. It depends on the device and what exactly the "reset" does.
If you force the watch off by holding the power button, it does not erase any data. If you hold the right button while powering it back on it will.
3 day old vivoactive hr touchscreen not working?
このアンサーは役に立ちましたか?
The vivoactive HR is different than the vivoactive. If the touch screen stops working on it and there is no damage to the display, it is most likely a calibration issue. Just reboot the watch by holding the left button 20 to 30 seconds or till the screen goes black. Then release the button and hold it for a second or two to turn it back on. When the watch turns back on it displays Garmin and calibrates the screen. Do not touch it while it says Garmin.
Thank you! This was so frustrating. Reset worked! Garmin did not show though.
I bought an hour before 3 months. After swimming in the pool right button for more options does not work, while the left buttom and touchscreen work. What should I do?
このアンサーは役に立ちましたか?
I have the same problem, could you fix it?
from where can i get the spare touch screen for my broken smartwatch
このアンサーは役に立ちましたか?
from where can i get replacement
過去 24時間: 2
過去 7 日: 31
過去 30 日: 137
今までの合計 132,683
7 件のコメント
this is the solve problem
هذا هو حل المشكلة
قم بتحميل هذا الروم للمطور الرائع mugurete
https://drive.google.com/open?id=0B_hRh3...
Ahmed Allam さんによる
I flash this to my smart watch but touchscreen isn't working.
Ristin さんによる
I left mine on the radiator for 5 min and seems to be working... for now.
James さんによる
It's not working because it's a $25.99 watch mine broke 2 days after I bought it.
Chris Allen さんによる
Chris Allen, your answer is really helpful. thank you very much for your insight and wisdom.
quijano_max さんによる
2件以上のコメントを表示
