メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ミシンの修理や分解に関する情報は、これらの修理ガイドをご確認ください。
Bernina 830 service manual
Zigzag not working. Need a service manual. If anyone has one. PDF form would be great.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
4 件のコメント
I'm having trouble with the bobbin tension. Any suggestions?
さんによる 共有
Hi @nannamarg ,
This link may be of some help. See 2nd post down.
https://thequiltshow.com/forum/bernina-c...
さんによる 共有
I have just bought a nearly new but quite old Bernina Record sewing machine, but the clutch release wheel that you release to load the bobbin will not release, will it be ok to use a pair of grips to release it, or is the some other way to release it?
さんによる 共有
I filled a bobbin with thread and now the knurled screw on the hand wheel will not re tighten. Can someone help with this?
さんによる 共有
コメントを追加
3件の回答
ベストアンサー
Hey Cheryl, I found a link to the manual of your specific model here and the user manual here. The threadguide/lubricating unit pdf can be found here. You can check out the firmware details here.
-Let me know how it goes.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
iApple your first link and your second link are identical. Neither one of those is for the service manual
さんによる 共有
Thanks for notifying me oldturkey03, the link has been replaced with the service manual.
さんによる 共有
iApple you are funny. The first link is now the user manual, not a service manual. Big differences :-)
さんによる 共有
コメントを追加
最も参考になった回答
Cheryl, this video may help. On the bottom of this page is now a pretty good service manual about the adjustment of your sewing machine.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi Cheryl,
I see it has been almost 7 yrs. since you posted this inquiry, but I have an answer for you. I joined a group called .... BTS@ groups.io ... and found all of the service manuals and user manuals as a free pdf. download. The BTS stands for Bernina Thirtysomething. I tried to send it as a link but it did not work. I sure hope this helps.
Happy sewing!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Cheryl さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 12
過去 30 日: 60
今までの合計 20,103
