How do I fix Flashing?
My Palm's screen and keyboard are flashing. I've tried removing the battery and powering down but it just keeps flashing. Can this be fixed?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
What you have done is the soft reset. Palm has 3 more types of resets.
- System or Warm reset
- Hard reset (possible removal of data from device)
- Factory reset (guaranteed removal of data from device)
Since you may loose data, I would suggest you connect the Centro to your computer & use Palm hotsync to backup your data.
The directions to do each of these resets are found on the Palm website here
http://kb.palm.com/wps/portal/kb/common/...
Try these steps & post the result (whether it worked or not) back here.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 14
今までの合計 2,160
1件のコメント
I did a hard reset on Palm Centro five times; data still there
Chris さんによる
