メインコンテンツにスキップ
Released in September 2012, the Le Pan S has a 9.7” screen and is identified by the model number TC978.
7回答 すべてを表示
Why won’t my Le Pan S charge when it’s plugged in?
My Le Pan S tablet will not turn on. I repeatedly hold the power button, and I still have a blank screen. When I plug it into the wall, nothing happens
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
2 件のコメント
My tablet won't stop deleting its like it stuck on deleting.
さんによる
the pad is not coming on when charging it
さんによる
コメントを追加
3件の回答
ベストアンサー
Try plugging the charger into multiple outlets to make sure the issue does not reside within the electricity being supplied to the outlet. If you have no luck, consider using a friend’s charger or purchasing a new charger to charge your device. If the issue persists, the problem you are experiencing is most likely due to internal components such as a battery. Please see a troubleshooting page located at Le Pan S Troubleshooting.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
After trying multiple solutions including purchasing new cords, pressing the reset button and other online fixes i resorted to opening ours when it refused to charge - i disconnected the battery and then reconnected it problem solved and the tablet works again
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
My lepan is in a different language.. how do I change language to English if I cant read the language it s in...bi
さんによる
コメントを追加
I have a new charger and I have never used this le pan its been sitting unused for years because we lost the charger then lost the l pan
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Wiaam Elkhatib さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 6
今までの合計 4,341
