メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Error 53 + Error 6 During Update
I have an IPhone 6 and it was dropped and cracked, the glass shattered around the home button and eventually fell out, Leaving the homebutton only hanging on by the ribbon. I was pulling my home button out of my pocket one time and the home button ripped off the cable and was gone forever. It worked but when IOS9 came out i tried to update it and received error 53 . Is there any fix? I tried reseting i and got error 6 i think. I've read around and heared its touch ID but i don't know of any fixes.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
Not possible to fix whatsoever unless you send it in to Apple.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Maybe not even then
さんによる
I just had my first run in with this error 53. We completed the screen repair a few months ago and he has had no issues with the device since then until the update to 9.1. We tried a few things first like DFU and recovery and RECBoot.
Here is what fixed it for me: We clipped in a new home button flex cable with the original home button and the replacement screen. We did the restore again and it worked! Took out the home button flex cable from back plate and reinstalled the screen and it is problem solved.
Hope this helps you too.
Brian
さんによる
コメントを追加
Chai, question for you. iPhone 6 broken screen and missing home button. Phones logicboard is wiped clean and ready to use and unlocked for any carrier it just needs a screen replacement to turn on. How do I go about fixing this phone and avoiding that error 53?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Don't update to new iOS. That's how people get into these situations
さんによる
So just put the entire phone together. New home button new ribbon cable that connects the home button. Turn on phone and all should be fine? As long as I don't restore the iPhone after I turn it on. Thanks.
さんによる
コメントを追加
Brian
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
brazins さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 285
