How to reboot my phone
My screen froze and my power button doesn't work how can I fix it
Without the power button you might have to wait for the battery to die
このアンサーは役に立ちましたか?
If the power button is damaged you have no way of doing this without taking apart the phone. Follow this guide, all you need to do is remove the battery connection then reconnect it again, plug it into the charger and it will boot up.
The phone becomes quite hard to operate when the On / Off button is not working so get that repaired as soon as possible
Best of luck
Regards
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 103
