メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
mother board repair, water damage
Water damage limited to top of the phone; no signs of any water under the top 5 sockets. there was a bunch of corrosion up there but I cleaned it with non-sweeping ultrasonic cleaner. I'm newbie for soldering but assembling the needed tools for this. the extent of my soldering knowledge is from the recent ifixit videos with Jenna. I could use some expert eyes on this to determine what I need to do; parts I will need. Or practical advice that should send in for repair and learn on some other boards. Phone seems fully functional except for the lcd, digitizer, and likely the two camera sockets. I was able to restore fully to iOS 9.0.2. getting into recovery mode (with use of the home button) and iTunes.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
The camera socket seems to have 1 pin completely burned out, clean again. And I still see some residual damage on other connectors.
Also I recommend flipping the board over, peel off the top shielding sticker to see the water damage below. Touch panel, home button and LCD backlight have relatively high voltage inside the phone, for this reason the chips and connectors are very likely to have water damage around them.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Pictures of the Back
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Breadman さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 381
