MBP can't access SSD when internal. Works via USB adapter
Hi all.
Installing a Crucial mx100 SSD into a 2010 Macbook Pro.
I installed MX100 on an external usb adapter, formatted it and restored an apple backup onto it.
If I boot onto that drive connected via the usb adapter everything works well.
If I then install that drive internally, and reboot, the ssd drive can not be seen and I get the question mark folder.
The guides here and elsewhere suggest the internal sata cable is suspect, so I bought one of those and installed it and the problem is the same.
I also have a second MBP that I installed this drive into internally and the problem is the same.
I updated the mx100 firmware to the latest and the problem is the same.
I spoke with Crucial support and they blame the sata cable, but I have already tried 3 of those.
Any suggestions on how to proceed? Try a 4th cable? How do I tell a good cable from a bad one? Or do I follow the pack and just try a different ssd?
Your help is appreciated
Pete
Update (10/23/2015)
Update: The problem was my mistake. The SSD was formatted with the windows format which worked via the usb cable, but not when installed internally. I reformatted the SSD using the Mac GUID format and it now works properly.
The cables were fine.
Pete
この質問は役に立ちましたか?
5 件のコメント
Crucial MX100 Specs
Dan さんによる
Did you check the systems firmware? Follow this Apple T/N: About EFI and SMC firmware updates for Intel-based Mac computers. Also did you verify the Crucial MX100 firmware? Checkout this site: Crucial firmware updates
Dan さんによる
Yes on the Crucial firmware, I updated to the latest. I'll look into the other item. Thanks
pete さんによる
Time for a new cable
Dan さんによる
bought the 2012 cable this AM. I'll report back when it is in.
pete さんによる
