メインコンテンツにスキップ
人気のGalaxy製品ラインを含むSamsungのAndroidベースの携帯電話の修理ガイドと分解情報です。
13180回答 すべてを表示
How to dismantle Samsung Galaxy Core Prime (XMG360V)
We need to perform a LCD & Digitizer replacement
We are working on one of these for the first time, cannot seem to find a guide, and also cannot figure out how to get the inner back case apart or off.
Any guides or suggestions are welcomed.
Thank you in advance.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
3件の回答
ベストアンサー
https://www.youtube.com/watch?v=FHZRZuhD... here its not in english but you get the idea
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I've just finished one of these, and it didn't go well. The way they've designed these things you have to use a decent amount of force to get things off and on--and it's not at all as easy or nice as a screen replacement on a Galaxy S3, for example. The new screen cracked the minute it got put on.
I used the youtube video above and he seems to have skipped over a few little things, like making sure the little metal earpiece gets back in, etc. But it's a good general guide. You will definitely need a heat gun, or an iOpener.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
If you can't find a guide on iFixit, then you're not going to find a guide anywhere. I also have never worked on one of these. You may want to try to unscrew any screws that are in the device and use an iSclack (iSclack) to pry the screen assembly off.
iSclackの画像
製品
iSclack
$24.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
William Aaron Vasilakos さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 2,153
