One of my keyboard bottoms stopped working, Number 0 , Solution?
Their is no cause for the bottom to stop (coffee spilling...) it just suddenly stopped. So what should I do in order to fix it ??
この質問は役に立ちましたか?
この質問は役に立ちましたか?
You may need to pop off the keycap to get under it to clean the junk that is causing your key to not work.
Here's a good writeup on how the keys work and how to pop the key cap off: Keycap removal & fitting There are a few YouTube vids if you want to see the process.
Once you pop the keycap off you want to be very careful on what you use to clean things here. I use distilled water for surgery stuff like dried soda or coffee or tea which had sugar added. I use a high grade of Isopropyl alcohol (85% or better).
In either case I use a cotton swap (Q-Tip) slightly damp as I don't want the liquid to drip down into the insides of the computer. Often I take the scissor part out to wash in a small container and then dry off before putting it back in.
For crumbs I use a soft paint brush and a can of can'ed air I carefully brush the keyboard area and then a short blast of air at a sharp angle to push the dirt out.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 110
1件のコメント
Have you tried blowing away dust or alike from under it? (Do NOT use a vacuum.)
Lillgubben さんによる
