メインコンテンツにスキップ
2.2 GHz (Turbo Boost使用時最大3.4 GHz), 2.5 GHz (Turbo Boost使用時最大3.7 GHz)もしくは2.8 GHz (Turbo Boost使用時最大4.0 GHz) L3キャッシュで6 MBのクアッドコアIntel Core i7プロセッサ
774回答 すべてを表示
Display assembly for 2015 model
Hi, does anyone know if you can use an earlier display assembly on this model. Can't find a 2015 display assembly listed anywhere.
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
6件の回答
ベストアンサー
The backlight Pin out is different on 2014 and 2015. They look the same and fit perfectly but the backlight boost circuit is different and pins are in different position than 2014 models. So, if you know how to redo the traces and manually jump the rails that will work.
このアンサーは役に立ちましたか?
スコア 5
6 件のコメント:
Thanks for this and sorry for the bleated reply. Your info was correct and we made these displays work. Thanks for the heads up!
さんによる
Is there a guide somewhere how to fix the pinout?
さんによる
Hi, i'm wondering the same thing, connecting a 2014 lcd displays the image but no backlight. Is there a way you can modify the LVDS cable? Like cutting/rearranging the wires inside to give the backlight the power it so desperately needs?
さんによる
@will how did you do it/is redoing the traces really necessary, or theoretically can you do the re-wiring within the cable?
さんによる
I just looked into this wondering the same thing myself and unfortunately it doesn't not feasible to rewire it. I thought maybe the pinout was differently ordered, but there's different data going through the cables between the 2013/14 display and the 2015. On the 2013/14, the backlight pins allow the main board to measure the current the display is using. However, on the 2015 the display measures the current itself, then reports back to the main board via a digital I2C bus.
さんによる
1以上のコメントを表示
コメントを追加
Which one do you want to assemble? From 2014?
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
I have a mid 2015, and I want to know if I can use a 2014 display.
さんによる
It fits perfectly.
さんによる
can use an earlier display assembly on this model. For example this one MacBook Pro 15" Retina (Mid 2012-Early 2013) Display Assembly
さんによる
コメントを追加
It fits perfectly, but the backlight doesn't work. Trust me, I have tried both model display assembly (2012 and 2013/2014).
The screen fits and the connectors do too, however the backlight doesn't work!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Yes he is correct, my mid-2015 MacBook Pro 15" i7, was defected, I calculated the Time and cost of replacing the LCD myself instead I decided to sell the parts and actually ended up making 50% of what I paid for the new MacBook Pro , profit - paid $2750 made $1,375. So I didn't take a loss that is just one I chose to do since Apple would not accept responsibility for the defected LCD which it 2012 MacBook Pro is also had the same issue. I love iFixit
さんによる
コメントを追加
No. It has different backlight rail . I used to sell the whole assembly with $425 on eBay and everyone trying to get lowball bargain and I stopped selling it.
Taking to Apple is just waste of money as everything is rip off.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
what was the reason why they made this change? if the size and characteristics of the screen remains the same. So stupid.
さんによる
It is profit generation and keeping the grip on supply. Every piece of Apple products includes a tiny bit of Steve Job's arrogant mentality.
さんによる
David! Your the man, I could not agree with you more all of the wasted time gas and money going back-and-forth just to be shut down by the "geniuses" but they know what's best hahaha
-I love iFixit
さんによる
コメントを追加
== Mid 2015 MacBook Pro 15" LCD
OEM Replacement @eBay ==
-I have a Mid 2015 MacBook Pro 15.4" and I droped my MacBook 3 months ago and and I never buy apple care (rip off) so Apple told me they could fix the LCD for over $1,300, I laughed, then searched everywhere to buy a LCD to Do a fix it myself, finally I found a few sellers on eBay which sell the LCD for around $480 and thank to iFix it, I was able to accomplish a less than $575 fix! Hope this helps. (Link to eBay below)
http://m.ebay.com/itm/Mid-2015-15-Apple-...
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
This is a really crappy quality assembly. I ordered one from the above link. They sent it to me in about a week and a half. It installs very easily, however the clamshell did not close flush, it does not contain the right magnet to induce sleep mode when it's closed, the poor closure causes the clamshell to pop open sometimes, and the screen assembly started to come unglued from the metal case. Overall it's cheap feeling. I returned it and had to settle for going to a Mac store for repair to get the right OEM part
さんによる
We fit displays all the time, a small fraction have been defective.
さんによる
I just wanted to post a update on what I ended up doing instead of taking a loss because of Apple I discombobulated this product and used eBay to sell 12 components and ended up making a very well amount of profit so I did not take a loss due to the LCD defect that was a blessing because I made over 1000 profit.
さんによる
Time consuming but very easy way to make a good amount of money [image|844705]
さんによる
コメントを追加
I’ve got almost the same question but slightly different. I need to fit 2015 panel on 2014 (2013 model year) Macbook, as 2014 isnt’ eligible for trade-in swap which makes the cost sky-high, just insane! Pretty much the price of the macbook itself.
Are there any ways to make it work?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
will さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 21
今までの合計 9,683
