メインコンテンツにスキップ
The Samsung Galaxy Tabs are Samsung's flagship tablets that compete with iPads.
Wont charge, keeps flashing and disappering?
My Samsung Galaxy 4 tablet wont charge. I plugged it in and the battery sign appears but it wont start charging. It either freezes on the battery sign or the sign appears and disappears. The tablet is off. Wont turn on. When I try to turn it on, it turns off quickly and the battery sign appears.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 35
38 件のコメント
now the chagrining animation wont show up
さんによる
Jojo, what model of the Galaxy 4 is your tablet?
さんによる
Um model? all I know is that its a Samsung galaxy 4 tablet. I tried a phone charger again and it is starting to charge but the screen keeps flashing black and when I turn it on it automatically turns off. should I just let it charge for a while and then reset it when it turns on?
さんによる
why does a phone charger work but now the one that's made for it?
さんによる
What size is the screen? The Tab 4 comes in a 7" and a 10.1" version?
さんによる
33件以上のコメントを表示
コメントを追加
15件の回答
ベストアンサー
Have you tried a different cable or try moving the connection around carefully to see if the charging port is broken you can also try a reset. Power button and volume down button at the same time till it says its resetting
このアンサーは役に立ちましたか?
スコア 27
23 件のコメント:
I tried multiple charging cables. I even bought a new one. I also tried the reset option and it won't work :( is my tablet officially garbage?
さんによる
How old is the tablet it does sound like its time for a new battery
さんによる
My new cell have 4 virus, what I do
さんによる
I'm having this problem only with two replacement batteries I ordered. Is this a known issue? Can it be fixed or is it time for a return?
さんによる
I have a galaxy tab I'm repairing for a client. I had the same issue as above with the power flickering and then shutting off. I tried a new micro cable and it fixed the issue. Thanks for the suggestion as I didn't realize this cable was damaged.
さんによる
18件以上のコメントを表示
コメントを追加
最も参考になった回答
Firstly, the battery is not holding a sufficient charge to boot because the LCD screen is constantly turning on. This causes a tremendous drain on the battery for a split second, if your battery is completely dis-charged like mine then you will never get ample charge into the battery for it to turn on hence why the screen keeps failing.
1. Open the back cover.
2. You will see 3x vertical ribbon cables. Carefully remove the on on the right, it is marked LCD (Convenient)
3. Plug your charger in and leave it to charge for at least 8 hours. (Use the wall socket adapter, it produced more current than a USB port on your computer) Now that the battery is not being drained constantly by the display the battery will have a chance to get some juice into it.
4. After you have left it to charge for some time unplug your charger (Crucial) , re-insert the ribbon cable for the LCD you removed making sure that it is in all the way so that the lines on the ribbon and the board are aligned.
5. Power on.
If it boots great. If not it may be time to purchase and replace the battery ($25 on eBay) and make sure that your charger has enough power to keep it charged and at 100% while in use. Beware of leaving any Li-Ion battery fully discharged for a long period
Good luck!
このアンサーは役に立ちましたか?
スコア 51
30 件のコメント:
Same problem is with my Samsung but my phone has some battery left. It was not charging , so I tried to charge it through switching it off and then it's kept flashing and disappearing. So, I switched it on and then i connected charger slowly, it's started charging.
And That's meaning charging port of mobile is broken.
さんによる
This worked for me! I accidentally unplugged the touch screen ribbon though instead of the LCD. Looks like my battery was/is shot and was near zero %. I imagine it only has a few charges left on it before it's completely toast. Will eventually replace the battery.
Thanks Gavin!
さんによる
I can't do that with my samsung tab because you can't open up mines help what can I do
さんによる
This worked for me. I had replaced charging port but still wouldn't charge. This did the trick. Keep it charged from now on. Thanks Gavin.
さんによる
I have a samung tab 18.4 and when the wall charger is plugged in, it continues to beep on and off, and the charging display also goes on and off. I bought a new charger, and problem still exists. I called Samsung help desk and they told me to take it to best buy and let them look at it. You pay all this money and nobody there knows or cares that your frustrated.
さんによる
25件以上のコメントを表示
コメントを追加
I had the same issue. This might sound weird but this is how I solved it. I tried all the different button combinations didn't work. While trying the combinations I realised the tablet felt cold. Kept the tablet against my body while charging for about half a hour while watching a movie on laptop. Body heat seemed to have warmed it enough to start charging. Suppose you could try other warming methods.
このアンサーは役に立ちましたか?
スコア 12
14 件のコメント:
Well this would explain alot. I put my tablet on my window cill and the air is freezing outside. Im quite stupid. Hopefully this works!! Thanks
さんによる
this worked for me.... only took 10 minutes. You are a lifesaver
さんによる
I can't believe this worked. Lol thanks!
さんによる
Hair dryer... 5 minutes!
さんによる
worked for me too thnx a lot for the advise
さんによる
9件以上のコメントを表示
コメントを追加
Anyone tried the volume down + power button hold down trick for 5-10 seconds?
このアンサーは役に立ちましたか?
スコア 11
10 件のコメント:
Yes, I did try that and the on screen came on. However, it still won't charge or power up. My screen continues to flash on and off.
さんによる
Thank you! It's so good that people bother to give solutions. Thanks!
さんによる
My new galaxy 8 is default
さんによる
I found out on my Samsung galaxy tab 2 10.1. That the hard drive is bad so I have to get a new mother board since the hd is integrated onto the MB. Ugh
さんによる
if you're charging your tablet with your computer it will cause that to happen too, switch to a normal charging source
さんによる
5件以上のコメントを表示
コメントを追加
Right now it sounds like you are having battery issues. what is the voltage/amperage of the phone charger you are using? If you do not have that written on the charger, what model is the charger?
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
You just said it right on the dot. It's a battery shortage. Both of my Samasungs did it and I refuse to get another one. They are both from Sprint bc I was eligible to get "Free tablets" and both did it within less than 3 months. It's aggravating and for whatever reason it's all android or Samsung products that always had issues with batteries bc my LGs and Samsung phones had the same issues with the batteries. I honestly think and believe when they say you're getting a new phone and tablet they give you refurbished ones bc my "brand new iPhone 6s I got from the actual store physically already had a dent on the back and th tablet had a scratch but they claimed it was brand new. So why am I having a software issue with my iPhone 6s if it's brand new? There're all a bunch of crock...thinking of switching providers now
さんによる
コメントを追加
The last time I used the tablet was about 4 years ago. Needless to say, the battery was completely drained. I plugged it into a charging cable connected to an iPhone 2.1A charger but the display just kept on flashing. Hmm. I then connected it to a wall charger with the same result. I was 100% convinced it had to do with the power supply not being strong enough. The 2.1A output may not be true 2.1A. I then switched to a portable battery charger with 5V 2.1A output and voila, the Samsung Tablet is now charging as it should. The display stopped flashing, and it shows a battery with a small green line at the bottom indicating it is charging.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I had the same problems. Wouldn't charge, screen kept turning itself off. I pulled the back off and disconnected the battery and could see that 3 of the 6 copper teeth on the motherboard (that the battery connector plugs into) had come off the motherboard and stuck themselves to the connector. No way to remove them without destroying them so I stacked two pieces of cutup old credit on top of the battery connector and snapped the cover back on. It's pretty tight in there already, so the additional pressure was enough to keep the connector pressed hard into the motherboard and the power connection complete. No more problems. Won't last forever, but it'll do the trick until I can sort something else out.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thanks Byron, your solution works for me.
さんによる
Byron, you're a genius! I had the same problem, battery charging icon blinking and not charging. I checked the battery connectors and realised for some reason that they seemed to be pushed back into the phone more than was necessary. Seems not all were making solid contact with the battery and hence the blinking. I simply pushed them out gently, using a pin, put back the battery and voilà, phone is now functioning 100% . All this after buying different chargers and changing batteries countless times!! Thanks again for your insight!!
さんによる
コメントを追加
Warming works! I placed it under my leg whole in bed for 20 minutes!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
The Battery connector might be loose, open the back cover and Solder it to make sure it is connected properly...
If the problem still persist then change the battery...
It should work...
Good Luck...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My Samsung tab e wouldn't charge was going take back off and unplug charging port but before I did I simply turned off tablet plugged in charger and it charged in no time
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Try cleaning the charger port with a paperclip- pick out any dust bunnies in there, and if needed carefully scrape the metal connectors. That worked for me.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have a Samsung Tab a10.1 and after not using it for a while and putting it to charge, the lightning/charging symbol came up but after a few seconds the screen started to flicker a lot. I tried two cables. Both connected to the USB front of my PC. Turns out it worked when I used the normal power plug and into the power outlet.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I tried the thing were you unplug the screen and that worked… when it died it had the same problem, I tried 8 hours first (it worked the first time) and the second time I tried 5 hours (worked after it died) and now it's staying on! Hope this helps!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The battery does not receive the charge. Someone tried to heat the battery surface with a hair dryer by about 10 minutes. This worked for me. You need to heat the battery. Then plug the charge.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
It is a very dangerous job Bro :)
さんによる
コメントを追加
conclusion tools - Heat the back of ur device using any method comfortable for u for abt 5-10 minutes this should warm up the battery meaning it can give more strength, then put it into charge straight from the wall, if this does not work it means your tablet needs stronger power because it is fully drained and is getting power than using it on the screen so put it into a 5V2.1A portable charger using only one of the USB ports wait a bit, if this does not work than you are going to have to disconnect the screen from the battery from the back this is so that the power can go straight to the battery. there are useful instructions before me..take a look at those i hope i was useful i'm sorry if i yapped on a bit :), had the same problem and was very frustrating, i came down to all the conclusions so it could be less hard for you guys :)
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hey man, heated my tab s6 lite for about 10 min, no changes, also ,i can't talk off the back dince it's built in. Any tips??
さんによる
コメントを追加
回答を追加する
Jojo さん、ありがとうございました!
統計データ:
過去 24時間: 13
過去 7 日: 110
過去 30 日: 517
今までの合計 459,296
