メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
締切られた回答
No microphone pickup when I make calls, what part should I replace?
Hi,
I have just replaced the screen on an iPhone 6. At first you could not hear anything on a phone call, nor could the other person haer you, however on loudspeaker you could do both still. I opened the phone again and cleaned connections etc, now you can hear what the other person is saying, but they can't hear you. Loudspeaker again works fine for both.
This is my first time fixing a 6 series so undoubtedly I have accidentally damaged something in changing the screen. I just would like to know which component or assembly is in charge of picking up voice on standard phone calls, is this something within the earpeice speaker, or is there a seperate microphone on that ribbon cable with the front camera etc which is most likely damaged etc? Just basically want to know what component to order to fix it, I'm sure it's just a smile accident on my behalf and I'm normally more than capable of replacing components on phones.
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
The microphone on the front camera is responsible for NR I believe. If it is defective the receiver won't be able to here the caller. Replace that assembly.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 71
