メインコンテンツにスキップ
2013年11月22日に発売されたMicrosoftの第三世代のXbox ゲームコンソールです。
709回答 すべてを表示
Xbox One turns on then turns off after a few minutes
My Xbox one turns on and I am able to use it for a few minutes, but randomly turns off. I tried playing Destiny and Forza 5, but as soon as the game loads, it shuts off. The last update that it got was the June 2015 update. Sucks, because it broke on the first day of summer vacation. I contacted Microsoft support, but they said I would have to send it in...I want to see if I can fix it before I do that. I have tried to turn it on recently, and when I do there is a system update. I tried to update it, and it starts doing the update. It was almost done but the console shut down on me.
Please Help!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 10
13 件のコメント
Well, I tried and Unfortunately, it didn't work... I have to send it to MS, they will give me another one... Still gotta pay $115 though...
さんによる
I'm not sure if this matters but i just remembered that it was stormy the day before it pooped out....not sure if that screwed it up or what.
さんによる
my console shuts itself off, im wondering if yours is doing it the same way. when mine shuts off (which is very frequently, in fact im not even using it anymire until its fixed) you can here a click inside the console, i think thats where the problem is. PC's have this problem too.
さんによる
also its not overheating i promis you, one morning, after it was off all night, it wouldn't turn on.
さんによる
@tronicsfix cockroaches?
さんによる
8件以上のコメントを表示
コメントを追加
9件の回答
ベストアンサー
It sounds like it could be overheating. I'd take it apart and clean it out of any dust with some Dust-Off or similar.
Xbox Oneのファンの交換
If that doesn’t help, try some of the other solutions in the Xbox One Turns Itself Off wiki.
このアンサーは役に立ちましたか?
スコア 5
11 件のコメント:
Ok, Thanks! I will have to try this. also when it turns off the power brick turns orange and idk if the console makes this sound or the brick, but it makes a little click right before it turns off
さんによる
I would assume that's from the device itself rather than the power brick. It is likely the fan coming to a stop or other component. How long have you had it, and in what condition is it kept in? Is there plenty of ventilation in the area?
さんによる
I have had it for about a year, It is well ventilated, there is no wire around it besides the power, and HDMI.
さんによる
Wow that's odd. That's my only explanation other than maybe it got damaged over that year? I don't know how well you take care of your Xbox so i don't really know
さんによる
I would still take it apart. You'd be surprised how much dust can collect in there and it can really fry your mother board if you don't stay on top of it. Even my laptop has to be opened up and cleaned.
さんによる
6件以上のコメントを表示
コメントを追加
This happened with my 360 every once in a while. I just put a fan on my Xbox and put it on an open surface not in like a shelf where is covered.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I spilled milk in my Xbox and I blowed dryed it out and it turns on and stay on for 15 mins then shut off any solutions?
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Did you take it apart to dry it? If you did, make sure there is still thermal paste between the cooler and the chip below it. Without that, the CPU/GPU will overheat, and then, of course the xbox will protect itself, and shut down. If you didn't take it apart, I would, and then look for anything resembling milk, corrosion, or burnt components.
さんによる
@josiah Fixing an xbox one s for my uncle that has this problem. when i took it apart, the underside of the motherboard was covered in what looked like rotten milk or melted ice cream. is q-tips and 91% isopropyl alcohol a good method of cleaning the motherboard? it may be in other components too but i've yet to find any
さんによる
コメントを追加
i spilled milkshake on my xbox
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Anyone know why my Xbox one keep turning off when I turn it on
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have the same problem too. It turns on for a few mins. and then suddenly turns off. I am going to take the cover off and clear all dust
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
So I unplugged my Xbox 1 s as it was on and brought it stright to my friends but when I hooked it up it turned off instantly ten I waited a hour and turned it off and it turns off after like 7 mintues
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
my xbox turns on and then shuts off
さんによる
コメントを追加
Ok so with my Xbox it does the same thing, it turns on then turns off I've taken it completely apart and blew on it but and put everything back but it still does the same thing, turns on then off. I've also done the power box thing unplugging it the plugging it back in and I show the lights that it's supposed to but when I go to turn it on it still won't work it still turns on then turns off. Yo can anyone help me with this because it's making me hella mad not cappin.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
So I turned on my Xbox 360 and it immediately shut off and turned the power button red, I’m not sure if the previous owner dropped it or anything but the fan is coming on and it is in a ventilated area just not coming on.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Nadeem Baksh さん、ありがとうございました!
統計データ:
過去 24時間: 8
過去 7 日: 28
過去 30 日: 132
今までの合計 95,678
