Screen hinge too loose
The hinge is loose and does not hold the angle to view it properly, falls back.
How to repair?
Thanks for the good work guys
OSCAR
The Clutch assembly itself is probably broken, not the easiest repair, 12" Clutch Assembly
このアンサーは役に立ちましたか?
I agree with matthewfrey, your problem is the display hinge clutch(es) which need to be replaced. based on my repair of this on a PB G3, it basically involves completely disassembling the entire machine, including the top of the case enclosing the display - can be done, but not for the faint of heart.
過去 24時間: 0
過去 7 日: 3
過去 30 日: 6
今までの合計 2,034
