headphones not working on PS4
The headphones are not working on PS4
They don't connect at all? Is it intermittent? Either way, the wifi antenna probably needs to be replaced. I know when this thing malfunctions controllers drop connection and wont sync as well. That being said, your controllers probably wouldn't sync if that's the case so before you attempt this repair I would check other headphones first to make sure. Here's the tutorial for the wifi antenna PlayStation 4 Wi-Fi アンテナの交換 Hope this helps!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 550
