メインコンテンツにスキップ
These white headphones are equipped with a remote and mic, and come with Apple's music players and iPhone. They are also sold separately. Released on September 9, 2008.
6回答 すべてを表示
How do I fix a broken volume button?
On the plastic piece on the cord of the right ear bud, there is the control piece that lets you control the volume and the play/pause. The button that turns the volume up is not working, so I need to either figure out a way to fix it, or at least remove the top part of the remote.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
最も参考になった回答
I don't believe that you can fix the problem, likely a piece of dirt got into the volume control and is blocking the contacts however I don't believe the volume controls can be opened without destroying them all together.
It may still be possible to get them replaced by Apple, if the ipod you are using them with is still under warrantee (all new ipods come with a 1 year warrantee which will cover you'r ipod and the in-ear phones you'r using it with, however can be extended to two years by purchasing the applecare program) to check if the ipod is still under warrantee input you'r ipods serial number into this webpage https://selfsolve.apple.com/GetWarranty....
Hope this solves the problem!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Just go to android, iPhones are trash ^.^
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Just get an android, iPhones are literal trash cans ^.^
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i tried to open mine and then i found this site :( i broke my freaking earbuds
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
John McWaters さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 10
過去 30 日: 19
今までの合計 14,957
