メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
1.3GHzプロセッサ、1GB RAM、500万画素のリアカメラを搭載した、7.00インチ1280x800ディスプレイの低価格タブレット。
Startup loop won't stop
At first... It was shut down and restart when it connected to internet, and afterwards it gone in a startup loop to the logo and shutdown again.
I cannot stop it or complete start my tab.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
2 件のコメント
i have your problem in my tablet can i ask you how you fix it pleas
さんによる
I have the same problem in my device. so far I can not solve this problem. if your problem was solved, please help me? thanks in advance.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Try a hard reset. Here's a video on how to do it: https://www.youtube.com/watch?v=L2nFwCzf...
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
i've tierd this and it faild "wipe data faild" error : connot get phone encrypt state"
i also tierd flash officail stock room but i couldn"t cuz it keep restarting (usb disconnect over and over) than tried to use adb to flash it but the "usb dubbing " wasn't actived
and no matter i try to installe rom (zip file) or any other package using recovery mode i get this" installation aborted"
さんによる
If you encounter the mount /data error or error mounting data message in the recovery mode of your MTK Android (e.g Tecno, Gionee, Infinix, Opsson, Innjoo etc) phone then your /data or /SD card partitions might be corrupted. To fix this, try the methods below:
Format SD card (If there's a slot for it)
* Remove the SD card
* Format the memory card on a PC (FAT32)
* Slot the SD card back in and boot the phone normally
* Switch off then boot into recovery mode
* Re-try the operation
Wipe data & eMMC
* Boot into recovery mode (volume up + power) and select Wipe data / factory reset
* If the above fails, boot into Chinese factory mode (Volume down + power) and select the option with eMMC in its name
* Reboot the phone
さんによる
thank you the quick answer but ....
there r no sd card on the phone just the internal storage 16GB i guess
pic : http://img15.hostingpics.net/pics/125395...
さんによる
コメントを追加
回答を追加する
wello25 さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 25
今までの合計 7,496
