Unit won't power up
it doesn't power up (batteries or ac adapter) after being plugged into the wrong adapter. Is there an internal fuse link that can be replaced or???
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Wow, not sure who woke this old question up, but here is my answer as well:-) there are actual three fuse on the PCB. The have the reference designator FU601,602, 603. FU 601 and FU602 are the power fuses.
FU601 part number VD7-3642-501 FUSE, Description KOA TF16AT2.50T
FU602 VD7-5071-000 FUSE, Description MATSU. DENKI UNHS206
Attached image show the location, check those for continuity. Hope this helps someone, good luck.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 5
過去 30 日: 20
今までの合計 3,364
