Very Frequent White Screen Of Death
Everytime I turn it on to use it, a white screen of death pops up. I reboot it by holding down the slide switch and after 3-5 reboots it stops showing the white screen.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
spotlightsrule this sounds like an issue with either your firmware or with your LCD. Check on hereabout the reset of your Fuze. If that does not work you do want to disassemble it carefully by using this guide Disassembling SanDisk Sansa Fuze. From there check the LCD connector for any corrosion, bend pins etc. You can try and reseat the LCD cable. If that should not resolve it I would consider replacing the LCD.
このアンサーは役に立ちましたか?
Did you try opening it up and checking the soldering points to make sure that there all in tact? That will most likely be your problem. I have a few more ideas of what the problem is if that was not it.
このアンサーは役に立ちましたか?
過去 24時間: 5
過去 7 日: 14
過去 30 日: 22
今までの合計 1,976
1件のコメント
Turn it off and then turn it on while holding DOWN BOTH BUTTON ON THE FACE AND THEPOWER BUTTON ON THE SIDE UNTILIT TURNS ON. It worked for me.
sonofkerry2
Pat さんによる
