メインコンテンツにスキップ
Repair guides and support for the Leapster L-Max, a hand held learning game system for children ages 4+, developed and released in 2005 by LeapFrog.
How do I get the battery to charge?
I cannot get the battery to recharge. The green light flashes while charging for more than 8 hrs. Battery still not charged. I have cleaned the terminals as recommended by the company, but no luck.
I am willing to buy a new battery if I could just find one.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
1件のコメント
Mine has batteries in it but isn't charger not even turning on what do I do is there anyway to reset it?
さんによる
コメントを追加
3件の回答
ベストアンサー
i searched ebay a little bit and found a battery cover/holder.
i don't know whats normally in the leapster l-max - but this holder looks like a 4 x aa battery holder: CLICK
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
さんによる
コメントを追加
Hi.
1. you can buy a wall charger (charge the battery connected to the wall socket) and connect to the ipod.
2. electro Shocks to your battery. You can use a power supply of 5V (for example an AC adapter with this power) and connect with a terminals to the pads of the battery this only has to be for a seconds, otherwise the battery will be burn.
after this process you can chek your battery with a multimeter
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
You plug in the charger to the wall, and then put it into your leapster device.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ruth さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 33
今までの合計 6,068
