メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Canon PowerShot SX160 ISは、16倍の広角光学手ブレ補正ズームと3.0インチ液晶ディスプレイを搭載した1600万画素のデジタルカメラです。
Date & Time Settings
Everytime I turn my camera on it wants me to set the time & date (it used to be ok) and it will not download the photos I took
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 8
コメントを追加
6件の回答
最も参考になった回答
Replace the CR1220 battery on the side of the camera. Instructions are on the site.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Same issue. Have to set date time every time camera is turned on. Here is what I found. When I put in a new cr1220 battery, even though it only fits in one way, I inserted it upside down. I only noticed this after reading this forum and noticing that the closure for the battery didn't set flush with the camera. I took it out, flipped it around and inserted it again and it did go in flush with the camera. Turned it on, reset date and time, turned it off and back on again and danced if it didn't hold my date:time.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Everytime I turn my camera on it wants me to set the time & date. When I changed a battery (CR1220) everything stays the same (camera does not set and remember time and date...)
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Hi,
Did you inset the battery in the correct way? Was it a 'new' battery?
さんによる 共有
Yes I inserted the battery in correct
さんによる 共有
コメントを追加
I have this problem too. I replaced the battery with a brand new battery that reads 3.24 volts unloaded. The battery only fits on way so unless you really force it you can't put it in backwards.
After replacing the problem persists. There are two contacts inside the camera that the battery touches when inserted. I suspect the contacts don't have enough spring to make a connection with the battery.
It looks to me that we are out of luck. Planned obsolescence?
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hi, Can you gently 'pry' up the contact a bit so as to increase the connection pressure when the battery is inserted? By that I mean that the battery actually pushes the contact back when it is inserted. It doesn't have to be far, it just has to push it a bit as opposed to just appearing to touch it.
さんによる 共有
コメントを追加
Can you help me set the time on my camera?
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hi @loismac ,
here is a link that shows how to adjust the time and date on a Canon Powershot sx160is, assuming that this is the model of your camera. https://www.manualslib.com/manual/482890...
さんによる 共有
コメントを追加
only need to know how to set time and date on my camera left manual at home
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi @larkygirl ,
Here is a link to the relevant section in the User Guide for a Canon PS SX160HS showing how to set the time and date. https://www.manualslib.com/manual/482890...
さんによる 共有
コメントを追加
回答を追加する
Yvonne Lang さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 24
今までの合計 11,530
