メインコンテンツにスキップ
13インチアルミ製Unibody, 2.0 or 2.4 GHz Core 2 デュオプロセッサモデルです。
574回答 すべてを表示
I need some repairing advice/help.
I am having trouble figuring out how to repair this MacBook 2008 Apple Macbook A1278 I have gotten from a friend. It was "hollowed/gutted" but I have some parts to it. My idea was finding another macbook same version to put the parts into the broken one. I am trying to revive this broken macbook because it has some things on it that I need, but can't do that if it doesn't work.
Here are some photos: (Screen is cracked and will not display)
Any help is appreciated.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
最も参考になった回答
Ashton, only you know what you have in your possession. Look through these guides and check the parts you have. You do not need to piece this together for "it has some things on it that I need" There are other means to access you hard drive, which is the only place your computer stores information. Getting an external USB hard drive enclosure that will allow you to access your drive on a different computer would be one way.
このアンサーは役に立ちましたか?
スコア 2
5 件のコメント:
I do not understand your answer.
さんによる
Check the guides listed in my answer. Compare the parts that you have to the parts in the guides. That will help you determine what you are missing.
さんによる
You do not need to rebuild this computer just to get "things from it" that you need. Those things will be stored on the hard drive. To access the hard drive all you would need is a external USB hard drive enclosure. Install your hard drive in that and then access the drive on a different computer.
さんによる
I would also like to use the actual computer too.
さんによる
You did not mention this in your original question. You clearly stated that " I am trying to revive this broken macbook because it has some things on it that I need, but can't do that if it doesn't work." No mention was made that you wanted to build it to use it. So I still think that you need to look at the guides and compare all the parts to the once you have.
さんによる
コメントを追加
The LCD replacement will be costly.
Beside Apple doesn't sell you internal parts, I've checked.
Just open the bottom side out using a small screwdriver & then remove the harddrive.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
You can always buy Apple, but you CAN NOT buy parts that are inside.
Many fools love to buy Apple, but when it breaks. You are out of luck because only they repair it and charge you dearly or forced to buy a newer model.
このアンサーは役に立ちましたか?
スコア -1
1件のコメント:
It can be helpful to troll Craigslist for a whole machine being sold for parts, especially in/around large cities. Also check independent Apple repair shops & PC repair shops which could have some Mac inventory.
さんによる
コメントを追加
回答を追加する
Ashton さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 148
