I cannot hear anything out of the right speaker
I can only hear audio from the left speaker and none from the right how can I fix it?
I suggest testing this by plugging the headset into a phone or computer with a headphone jack and test the audio to ensure it is the headset itself and not the adapter.
If it is the headset you may need to replace the speaker on that side of the headset.
このアンサーは役に立ちましたか?
The right side of my speaker stopped working when I moved the tip of the cable. I could it open a bit to see what was the problem and I noticed one of the cable was ripped. That may load to the right side, and if I can somehow connect it back (the other end must be tucked into the cylinder thingy) I'm sure it'll start working again.
このアンサーは役に立ちましたか?
Thank you
SusanJ Bolden
My volume&sound is not working on my Huawei vision3LTE
Thank you help
このアンサーは役に立ちましたか?
過去 24時間: 4
過去 7 日: 10
過去 30 日: 19
今までの合計 6,560
