メインコンテンツにスキップ
モデル番号A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544回答 すべてを表示
締切られた回答
No power when plugged on AC
I have 3 different Magsafe adapter.
None will power up my Macbook Pro 17" Unibody 2010.
I could work on it until the battery went to 0%.
Is it a battery problem, or a more difficult power problem ?
I tried reset SMC twice.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
If your battery drops below about 20% the unit will not power up from just the Mag-Safe adapter. Try to get a charge into the battery. Are you getting amber lights on the adapter when trying to charge?
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thank you for your kind reply.
My battery had 852 cycles and is 55 %.
No amber light when Magsafe is plugged.
No charging of the battery (even before battery was totally discharged, I had a message on battery menu in Menu bar : Check you battery).
Problem is also that battery model seems very difficult to find.
さんによる
コメントを追加
I replaced my old 15" MacBook Pro battery with an eBay knock-off. It had a plastic rather than aluminum cover, but aside from that, worked better than the first replacement I bought directly from Apple.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i have also a macbook pro 15 in. A1286and the charge on the charger shows green 4 about a minute then it just goes away then still no charge on the macbook pro
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
can any body help me with this one I really appreciated thank u
さんによる
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 134
