メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
replaceing iPhone 6 accelerometer
When ever i open my compass it just spins like crazy, it dose not stop moving. same when i am in maps my direction is constonally flipping around. it was in watter but i took it to CPR cellphone repair (in st louis) and they replaced the screen, gave it a watter damage cleaning, and a new power flux.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
5件の回答
最も参考になった回答
Who the heck charges anyone. $60 to not fix a phone! Bga work is not something you "try"
This problem is not necessarily one specific ic--use a multimeter to see what exact line is down on your board by comparing to the schematic and a known good board. Water damage can affect an ic, but more common is a short on a capacitor serving that ic
このアンサーは役に立ちましたか?
スコア 6
1件のコメント:
this totally worked ..Thanks so much
さんによる
コメントを追加
It sounds like the gyroscope is the issue and not the accelerometer. This is an IC soldered to the board, unless you have the equipment and some soldering experience I would not attempt to repair it.
このアンサーは役に立ちましたか?
スコア 3
8 件のコメント:
that component is kind of notorious for dying in water damage phones, maybe as much as 60% of recovered water damaged iphone 6 turn out to have this problem.
さんによる
I have some experience with soldering.. How much dose the part cost?
さんによる
Old turkey is correct iPhone 6 uses two accelerometers and one of them is a combo with the gyroscope. What I meant was the error you are seeing is caused by gyroscope (most likely). If the gyroscope were the issue you need the MP67B and it should be in the $15-20 range here in the U.S.
さんによる
If no underfill you can reflow like galloham mentioned. Use a heat gun the very least preferably a temperature regulated hot air station
さんによる
I got a water damaged iphone 6 today. Corrosion was bad on the board. After water damage treatment gyroscope was bad. Good news, no underfill on this one so I tried reflowing it and it did not work for me. Customer did not want to pay $100 for me to replace the ICs so... Ill never know :)
さんによる
3件以上のコメントを表示
コメントを追加
rythqu, the iPhone 6 uses a InvenSense MP67B 6-axis which is a combination of the gyroscope and the accelerometer. Having experience with soldering may not be quite sufficient since this is a LGA package IC . BTW, according to Chipworks the iPhone 6 series uses 2 accelerometers. The one right besides the InvenSense is a three-axis Bosch BMA280 accelerometer.....As for cost and where to get it, I'd suggest a good internet search and choose something that is close to you etc.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Replacing if fully is the last thing that I would want to do, that would be a lot more in depth then I could handle my self.. The cpr stole told me that it would be 60$ and their would be no guarantee that they could fix it(they said that they can't order it but I found it online), so I was hopping that I could just fix it my self
さんによる
コメントを追加
don't try replacing the IC yet.. just heat up the gyroscope IC/ accelerometer IC then try to see the result..
i had this Problem once after repairing a water damage of an Iphone 4s heating up those two ICs solved the problem thou i dont know which one was the problem.. you can try one at a time or both at once.. Good Luck
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
How would you re omen heating it up? First thing that would come to my mind is a hair dryer but I feel that is wrong
さんによる
hair dryer will not provide enough heat at appropriate time.. u should use heat-station or heat-gun with a small diameter heat flow and center the heat on only those ICs for just 5s..
something like this should be good http://www.5thpostulate.com/pr/solder-re...
but u can try with the hairdryer and make sure other parts are not effected.. and i am sure the time will be loger myb 15-20s
i used head-gun-station
さんによる
If I was to do it my self, would I need to take it fully off or could I do it with just the screen taken off?
さんによる
all detachable parts should be off the main board.. and battery is a MUST TO DETACHED
and careful is needed
さんによる
コメントを追加
Hello, I have the same problem, my phone droped in watter and my gyroscope/accelometer is very slow. When I open compas it hardly turns and when I want to use as vertical or horizontal level, it's very slow and evry time it's more inacurate. So I belive that the IC (Gyro and Accelo) are problem, where can I buy the chip for iPhone 7.
Can you provide me with any links where are the solutions, I can't finde anything :/
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
rythqu さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 6
今までの合計 14,905
