Why does my gameboy mirco stop at the gameboy screen?
When I turn my gameboy mirco on it works like it normally would but it stays at the gameboy screen. I tried putting other games in and it does the same thing. What do I do?
Did you check that nothing is blocking contacts inside the game-cartridge or in the Gameboy Micro? You can try a little bit of contact spray or to cleanse the contacts first with something like "Kontakt LR" or a similar product. Kontakt LR (www.crcind.com) has a brush included to be able to clean the contacts.
このアンサーは役に立ちましたか?
Use a high percentage isopropyl alcohol to clean the contacts on the GameBoy and on the carts.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 9
今までの合計 2,405
Does the interface between cartridges and the system appear to be damaged in any way?
rab777hp さんによる
are you sure there isnt a lose connection inside the unit
Tacotuesday さんによる
