メインコンテンツにスキップ
2.4GHz, 2.7GHzもしくは2.8GHz クアッドコア Intel Core i7 プロセッサ (Turbo Boost 最大 3.8GHz) with 6MB 共有 L3 キャッシュ。
20回答 すべてを表示
MacBook Retina Pro 2013 - Broken Right Fan ZIF socket
I recently spilled beer on my laptop (Early 2013 15' Macbook Pro Retina), resulting in some corrosion on the connection between the logic board and the top case/keyboard. I soaked it in iso alcohol and removed the corrosion with a fine brush. After putting it together, it works fine (as far as I can tell)!
Unfortunately, when re-assembling the laptop, I broke the retaining flap on the right fan ZIF socket. For reference, it's the socket shown here:
https://d3nevzfk7ii3be.cloudfront.net/ig...
The socket is still intact, and the cable fits in it, but I think without the plastic latch/flap the cable won't engage. I put some electrical tape under the cable to hold it parallel but that doesn't help it engage with the socket.
I ran the apple hardware diagnostic tool (startup while holding the 'D' key) and it gave me this error - 4MOT/4/40000002 - Right-Side-0. It seems like the laptop can't recognize the right fan without the socket being locked down.
Is there any way to fix just the flap? Or the ZIF socket? I have some experience doing SMD soldering so it's not out of the realm of possibility to replace the socket itself if I can find the part.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
1件のコメント
Thanks! Do you know any UK distributors that stock this part?
さんによる
コメントを追加
2件の回答
ベストアンサー
Cam Bennett, the connector is a FF14A-5C-R11DL-B-3H. It is available at places like this and many others. The only proper way to fix this would be to replace the connector.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
How did you fixed this? Same problem here
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I'm sure Cam got the replacement connector from part info and link @oldturkey03 gave her. Then either had the skills to replace it or got someone with micro soldering-skills to do it for her.
さんによる
コメントを追加
回答を追加する
Cam Bennett さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 9
今までの合計 1,543
