Unresponsive white screen on startup
Hi there,
My iMac ("Core 2 Duo" 3.06 27-Inch (Late 2009)), has suddenly started showing a blank white screen after the startup chime once powered on, no apple logo or question mark, nothing. I run both Yosemite and Windows 7 via Boot Camp.
I have tried a number of 'white screen of death' fixes, such as PRAM reset, SMC reset, booting into safe mode, booting into target disk mode, single boot mode etc. The imac is completely unresponsive to any startup commands except the PRAM reset, which successfully restarts the iMac but does not seem to help. Also, holding the option key no longer shows me the available disks.
I'm beginning to think this may be a hardware issue, but if so, what?
Considering taking this along to my local repair shop but I'm a student and can't really afford that, hoping there are some cheap fixes I could attempt.
Many thanks for any insight or advice you guys might be able to offer.
Oliver
この質問は役に立ちましたか?
4 件のコメント
This on a 21.5" same as above
mercidee1 さんによる
Did you solve this issue? The same problem just happened to my iMac tonight. My iMac motto is the same as yours so I'm wondering if you were solution can be applied to mine.
weimings さんによる
Zap the PRAM. (Command, option,P, R. Let chime twice. Then boot holding down Command, option and R. Reinstall OS from internet. Then you migh have reboot holding down option key to reset the boot up drive.
macmike さんによる
I had this problem also now with my iMac. I have to make so many retries in restarting with Option key. SOmetime I could get in and most of the time will be stucked with the white screen. Were you able to get your issues resolved? If so what was the permanent fix ?
Edwin Cortez さんによる
