メインコンテンツにスキップ
モデル番号 A1367/ 8, 16, 32 もしくは64 GB容量
915回答 すべてを表示
締切られた回答
What can I do to fix this?
I replaced my screen and I got everything working great, but the screen wouldn't sit flush. So, after fixing that I tried to connect the lcd plug (?) into the corosponding spot thats next to the rear facing camera.
welp, some of that crap broke off (I had a horrible time trying to get that thing in.
Here is a link to a picture explaining what I'm trying to say.
broken part
broken part
Now my screen no longer comes on and it got little hot in that area.
what can i do to fix this or what parts will be needed?
Thanks for all help
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Yes that will need replacing , its the LCD digitiser , it is quite a tricky fix as it requires soldering knowledge and good equipment , but there are quite a few skilled repair shops , should be around £30 depending on location , ebay has a few in uk if you search , also you can buy the part yourself for around £5.00 , hope that helped
Update
If your in the uk i could do it for you at said price £30
Just drop me a message Or reply here thanks
Update
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 57
