メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
iPhone 6 and 6s Screens
Are iphone 6 and iphone 6s screen replacements the same or different?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
コメントを追加
6件の回答
ベストアンサー
The LCD itself will apparently be the same as the iPhone 6, so they can more than likely be used on the 6S for refurb purposes, the things that will be different are pretty much everything else, shield under the LCD(will have hole for force touch), frame will be different to, and probably the glass etc.
The third party companies that refurbish screens will end up finding a way to use the iPhone 6 LCD's with the 6S, only thing they have to worry about is the shield with the hole in, I was reading about this somewhere but can't remember the site.
That's if the screens are the same anyway, like I said, read it off a site, so take it as a rumour for now.
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
Thank you for the insights. It's very much appreciated:)
さんによる
i need a iphone 6s lcd
さんによる
コメントを追加
The 6s has not been released yet so nobody knows :)
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thank You for your response. much appreciated:)
さんによる
コメントを追加
Although the pictures show the same rounded edges of the glass display as seen in the iPhone 6 and the speaker and the front camera appear to be in the same position, there are a couple of notable changes that point to the incorporation of Force Touch into the new displays.(The left one is iPhone 6s panel.)
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
News of iPhone 6s has been increasingly posted on the Internet. After the leak of spy images of iPhone 6s screen assembly, Flashtechllc.com revealed the prototype images of iPhone 6s for the first time, which is similar on the outlook and size compared to iPhone 6.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It is VERY DIFFERENT!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The 6S has a few different features relating to touch usage as compared to 6. So I believe there will be differences in the replacement screen too. The display quality should remain the same though. Only the functionalities will be different. Have dealt with this query a few times while dealing with customers for my company, The Fone Stuff.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Chung Nguyen さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 15
今までの合計 45,791
