メインコンテンツにスキップ
Mid 2010 Model A1278 / 2.4 もしくは 2.66 GHz Core 2 Duoプロセッサ
794回答 すべてを表示
締切られた回答
Locating water damaged component on logic board
My 13" Mid 2010 MBP was not waking up from sleep mode, in order to "re-wake" it I was forced to disconnect the battery for a period of time then reconnect and power it back on.
In order to solve this problem I preformed several SMC resets and even replaced the battery, the problems stopped for a week with my new battery then started back up again.
Then one day it just would not turn on, I took it to simply mac and they diagnosed it
So at this point I do not want to spend that much to fix it, what is the best way i can locate this so called "water damage"? (this laptop did not go near any liquids at all) or is it something else?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
Normal cost for this type repair would be around $350.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I usually do liquid cleans on Macbooks for $75. I must be WAY undercharging haha.
さんによる
That's not just for a clean but for component failure diagnostics and repair. If you'll do that for $75 I'll send them all to you.
さんによる
コメントを追加
最も参考になった回答
The board costs about $200-$300. It is only natural for someone who is being raped paying California taxes & store rent to charge $100 to $200 on top of that part cost to install it, particularly when there is a good likelihood of that six year old POS board dying and you coming back for warranty.
99% of the time this kind of thing is liquid, it doesn't happen on its own. Open it up and go hunting, corrosion near U4900 or BIL is first guess.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
As a temporary solution for sleep you could use hibernation. Type in Terminal:
sudo pmset -a hibernatemode 25
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 193
