メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
Black screen, backlight problem?
I recently dropped my iphone 6 in the sink briefly. It was water damaged as the LCI shows red. I can still charge it; see it in iTune; and if I shine a flashlight on it, I can see the display, but the screen appears black without light.
Does it mean backlight fuse is burned? If so, I don't think I can do it without some real fine tools and micro scope. How much would it cost for the repair shop to fix it?
Thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 12
1件のコメント
Thanks for the answers. The reason why I suspect it being the backlight problem is that I can still see it clearly with a flashlight, and I can gesture and all the things. I thought if there's an LCD issue, I won't even see that.
さんによる
コメントを追加
4件の回答
最も参考になった回答
Could just be the LCD. Clean the logic board and try another LCD
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
If the screen looks very dark but you can see the screen while using a flashlight or looking really closely its more than likely a backlight coil on the logic board so a new LCD/screen wouldn’t fix it. You’d have to take it to a repair shop that specializes in microsoldering and board level repair
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I would try another screen. I would rule that out before venturing into the backlight repair. Also, look at the connector when you take it apart.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
So I could be wrong . But it will be easier if you join fellow detailed pictures . If they are filters that will have a different color .
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Joe Zhao さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 10
今までの合計 28,675
