メインコンテンツにスキップ
Support for tablets by Coby, including the Kyros line.
64回答 すべてを表示
Where can I find a replacement battery?
My daughter's tablet, a Coby MID-7036 will not power on and not charge. I have it taken apart and see the battery connector is soldered onto the motherboard. I can de-solder it or snip and strip the wires to connect a new battery but I can't find a replacement battery anywhere. Any ideas where else I can look or is there a way to use a battery with similar dimensions and capacity?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
コメントを追加
1 件の回答
最も参考になった回答
I was able to search the s/n on the battery case itself and found a replacement on Ebay. I sniped the wires off the old battery and soldered the ends to the new battery and used heat shrink tubing to cover everything up. Device charged up and is good to use.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Hi Brian
I thank you for the advise.
How much was the battery and how Long did you wait to receive the battery
Thanks
さんによる
It was $8.00 US and took about 7 days
http://www.ebay.com/itm/3-7V-2400-mAh-Po...
さんによる
コメントを追加
回答を追加する
PolishRifle さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,045
