Compatible Samsung hard drive for iMac EMC 2389
What is compatible hard drive replacement for iMac EMC 2389 with Samsung hard drive installed? (Hard drive model is Samsung HD502HJ, it's a factory installed hard drive.)
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Samsung HD group was bought by Seagate. If you want to replace it you can use a Seagate drive as the sensor cable connection is the same. If you want to use a different drive here is the Apple P/N's for the different sensor cables:
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 8
今までの合計 275
