メインコンテンツにスキップ
Repair guides and support for home heating, ventilation, and air conditioning system repair.
346回答 すべてを表示
What does a suddenly louder AC fan (right?) mean?
It started last night: The AC is really, really loud when turned on. This happened last night. Smacking the side of the unit makes the sound normal for a few minutes.
Model: Kenmore 580.75050801
Approximate age 1-2 yrs
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
最も参考になった回答
a louder fan is sometimes a sign for a loose or broken part around the electric motor
parts 8-C and 9-C would be my first guess - but there are other possible parts that could "transport" the vibration
click here for the breakdown
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
さんによる
コメントを追加
1) check the motor bearings. Do this buy spinning the fan blades with the DISCONNECT OFF. Is it making a noise? Does it feel like metal on metal?
You can also see if shaft seems to wobble while spinning.
If bearings are bad replace motor.
2) most likely that loud sound is your compressor. Refrigerant migrates into the oil while the system is off. When your crank case heater goes out it may sound rough for a minute while the oil heats up and the refrigerant is boiled off the crank case oil. Check this and get back to me.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
By* not buy. %#*@ autocorrect
さんによる
コメントを追加
回答を追加する
HealthyPizza さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 14
今までの合計 3,777
