メインコンテンツにスキップ
Samsung's second-generation smartwatch, released in April 2014 and powered by a Tizen-based OS. Model Number:SM-R380.
60回答 すべてを表示
Samsung gear watch charger is not charging my watch.
My samsung gear watch will not take a charge, don't know wether it's the charger or the watch. I don't think it is the watch because it was working fine when it was charged. How much are the charges?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
1件のコメント
the contacts on the watch are scraped off. can I order the re64 board
さんによる
コメントを追加
3件の回答
ベストアンサー
Same issue...my charging contacts on the back of the watch were worn away. From another thread I learned about the Circuit Writer, a pen that dispenses conducting ink. A drop on each contact and my watch charged again, and the pen was only about $12. Hope this helps!
このアンサーは役に立ちましたか?
スコア 4
3 件のコメント:
What store did you get the Circuit Writer from?
さんによる
Apologies for not responding sooner! I picked it up from Ama zon, was about $12.
I've used it twice more since I posted this, and my watch is still charging.
さんによる
A follow-up: It's 8 months since I first used the Circuit Writer on my fading contacts, and have used it 5 times, and finally can't get it to charge any more -- I believe there just isn't enough of the original contact left for this hack to work.
So I ordered a brand new (old stock) Galaxy Gear 2 to replace my old faithful. $120 including shipping from Ebay, and it will be here tomorrow.
It was well worth extended the life of my watch by 8 months for $12, and still recommend you try the Circuit Writer trick! Thanks for following along.
さんによる
コメントを追加
Where can I send my samsung galaxy gear watch for repair? It will know longer take a charge.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
the outer case of my gear 2 neo got broken. where can I find a replacement?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
wayne dozier さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 16
今までの合計 13,380
