Display blinking when turning display back and forth
Hi. I have a MacBook Air 2011 13" and I have this problem.
When I'm trying to turn the display I have some flickering and lose of colour. Sometimes the picture becomes frozen.
That accrues when I'm open my laptop and turn it on after some time in sleep. So it is cold. When it heats up a little bit, problem seems to go away.
I opened it and make a little test, pushing the display cable to what happened. It seems like pushing the cable helps, while not pushing cause flickering even on "heated" laptop.
Do you thing that the problem in this cable or in some other place?
1件のコメント
I experience the same problem. I also opened it, but the display connector nor the cabel does not react to some pushing and movements. In my case it seems to be inside the display assembly. I reacts to slight twists or pressing on the left border. I wonder if the display assembly can be taken apart without destroying it completely?
Did you had any luck with your repair?
Stefan Luechinger さんによる 共有
