screen suddely becomes blank.when I switch off and on it,not working
my phone display screen suddenly becomes blank.when i switch off and on,im not getting the display.it just hangs on
この質問は役に立ちましたか?
この質問は役に立ちましたか?
if you get a blank screen on a slider phone it is probably cause due to a broken flex ribbon cable connecting the lcd portion to the base of your phone.
このアンサーは役に立ちましたか?
+ agree on that
If you get a blank screen, try lighting a torch to the display to check that the images are visible. If are visible, there might be a display illuminance problem. If there is a illuminated blank screen, there is a bad flex ribbon cable connecting the display to the motherboard.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 1,408
