メインコンテンツにスキップ
モデル番号A1288/ 8, 16もしくは32 GB容量
451回答 すべてを表示
4.0 Update Rendered my iPod Useless
16 month old unit, always worked flawlessly.
Here's a breakdown of what lead up to the problem:
1) Updated to 4.0 software
2) Sorted apps into folders (primary reason I wanted to update)
3) For a day or two, some apps worked okay, some would freeze up and then take me to the apple screen of death (white apple on black background)
4) Contacted Apple customer service. They said to do a restore.
5) Did restore, but in the middle of restoring it just 'stopped' and never re-started
6) Now, my Ipod is frozen at the screen of death. When I attempt to restart holding power/home buttons, it takes me right back to the same screen and NEVER does anything else.
Please help if you can. I don't want to be stuck with a $300 paperweight.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
4件の回答
最も参考になった回答
did you jailbreak it?
try to put it into dfu mode and restore it
here is a video that shows you how to get into dfu mode: CLICK
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
+ agreed
さんによる
コメントを追加
Try restoring from other computer.
I once stuck in the middle of restoring process (maybe just like you), after restoring with other computer, my iPod Touch 2gen works fine, also works fine on iOS 4.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
It is not jailbroken.
さんによる
i updated a few ipod touch 2g MB models and had no problems with them - but all were jailbreaked
さんによる
コメントを追加
I would suggest another computer also. Mine was stuck in the one color screen mode after attempting to remove 4.0 due to many issues.
I put it on another computer using the hold both buttons and then let go of home button awhile after plugging into a computer and it came out of the hung state. It still has 4.0 on it but now most of my apps have been updated to work with 4.0 which helps
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Thanks. I finally got around to trying this, and it helped to a point. My system still shuts down fairly often, and it's a real problem trying to get it to restart again. Also, my apps still crash while trying to open more than half the time and the other half they shut down a few minutes into using them. could this be due to some issue with the 4.0 upgrade on my 2nd generation device? Ever since the update I have had nothing but problems. and feel that it is Apple's fault for not fully testing their 4.0 upgrade on the 2nd generation devices. I'm almost ready to just toss this thing in the trash!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
i would try to downgrade it, if 4 won't work, it might be better to use the older ios insted of a non working ios
さんによる
コメントを追加
回答を追加する
Mike さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,902
