メインコンテンツにスキップ
Appleが発売したiMac Intel 20インチの修理ガイドならびにサポートです。
892回答 すべてを表示
Can you drop the speed on a Toshiba DT01ACA200?
the guide indicates that the drive is compatible with 20 inch iMac 2118. but after install the drive spins but does not display on the desktop or in disk utility. used universal drive connector to usb 2.0, same result. there don't seem to be any external jumpers. I didn't find anything on the toshiba site re: modifying speed.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
The new drive from Amazon arrived. I installed it in the manner you suggested and it's now working fine. The deviation I made was I used lagunitas ipa rather than wine, which did not seem to be a problem. Thanks again.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thats Great!
さんによる
コメントを追加
最も参考になった回答
The drive you got still needs to be formatted and prepped with the OS (Mac OS-X). Which is why you are stuck here.
You'll need to find a friend with a Mac to create a bootable external disk ideally a USB thumb drive or using the SATA to USB adapter with your disk. The USB thumb drive will give you a backup bootable drive which over time will be helpful to have (for the next time).
OK, you've managed to find a friend with a Mac bring your thumb drive (16GB or larger) or your drive with the adapter. Lastly, don't forget the two bottles of wine for payback! ;-}
With your friends Mac delete the partition on the drive (USB thumb drive or your drive) using Disk Utility. Then setup GUID partition mapping with a Mac OS Extended (Journaled) partition. Once done download from the App Store the OS installer (if your friend doesn't already have a copy of it downloaded) make a backup copy, then run it. Make sure you select your drive and install the OS onto it. Once done restart the Mac system holding down the Option key to get to the boot menu select your drive and see if it boots up if so you're almost done! Copy from your friends Mac the OS installer onto your drive so you have it. If you did this on the USB thumb drive you'll repeat the process to install the OS on your systems internal drive when you get home. Shut your friends Mac system down disconnect your drive and restart the system.
Enjoy the rest of the wine! When you get home repeat the task on your HD or install your HD back into your system. I do strongly recommend you make a bootable backup drive as you will need it later for repairing your drive when it gets into trouble.
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
The drive does not display in disk utility, when connected with the data usb adapter or when installed.
さんによる
If you are not seeing it within Apples Disk utility via the USB to SATA adapter it sounds like the drive is bad. Where did you get it?
さんによる
amazon. seemed to be undamaged when i opened it.
さんによる
Is the SATA to USB adapter powered? 3.5" drives do pull more power than what the USB port can offer. Make sure you have a independent plug in power adapter for the adapter and it is working. Disconnect the USB able from the system the drive should start up, if not the lack of power could be the issue here.
さんによる
the drive is connected to an ac-dc adapter and clearly is getting power. i also tried connecting to a mac mini late 2009, 2.26 intel core 2 duo via the usb adapter, same outcome.
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
joe さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 367
