How do I re-attach the bezel to the rear panel?
Theres a gap between the bezel and the rear panel, how do I fix this ?
thank you
David
この質問は役に立ちましたか?
thank you
David
この質問は役に立ちましたか?
the only way to get this done, is to disassemble the phone, fix it and reassemble it.
use the rear panel guide - the bezel is pretty much the last part you can remove on the iphone - so getting to it means, removing everything.
good luck with that
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,226
