メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
How can I fix a loose screen?
When I touch my screen it moves ever so slightly up and down. Is there a way I can replace the rubber seal between the iPhone glass and the metal housing to make it fit more snug? If this is possible, where can I find the parts? Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
コメントを追加
6件の回答
ベストアンサー
Sounds like a refurb defect. If it is a brand new phone--return it! Cheaper aftermarket iPhone 6 screens have a 'lift' between the screen glass and the plastic bezel. A quality iPhone 6 screen that is properly installed will not have a lift. Correcting a lift on a cheap screen is a pain.
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
Funny I'm having the same problem and I got the screen from this website and its apparently OEM.
さんによる
コメントを追加
Hi,
Firstly, it's not a rubber seal, its plastic.
Secondly, your best bet is try and glue it down, as it appears that these iPhone 6 replacement screens always peel away from the frame.
このアンサーは役に立ちましたか?
スコア 2
7 件のコメント:
Firstly, it's a brand new phone.
Secondly, don't care what it's made of.
さんによる
He was only trying to help...
さんによる
Thanks David, some people don't like help these days...
Wow bub, don't come on ifixit if you don't want answers, you should drop the attitude. If you went to anywhere with that attitude for help they would of told you to gtfo.
If it's a brand new phone, common sense should've told you to take it to apple.
さんによる
Plus, you never mentioned it was a new phone in your question, so everyone would have assumed you've had the screen replaced by a third party screen.
さんによる
If its a brand new phone take it back
さんによる
2件以上のコメントを表示
コメントを追加
I have the same problem. It's most likely if you relize when you charge your phone and the battery becomes very overheated, the battery is faulty. This is not normal. Sometimes the battery will overheat but not to an extreme extent. Just take it back to Apple and they will give you a new one free of cost. I got a new one too. But this may be a bit too complicated to fix at home. Guess that upgrade will have to wait. :)
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
The glass is adhered to the plastic frame by hot glue.
The screen gets hot the glue gets soft.
I've seen this multiple times on GENUINE iPhone 6, it looks like it's becoming a common fault.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I use a 2 component expoxy glue and a injection needle to apply the mixture very precise.
Apply the glue on the frame and place the frame on the glass, apply pressure for 2/3 hours and it wont come off ever again.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Does that really work? :'( the problem is happening on my lg g3 too :'(
さんによる
what kind of epoxy and injector do you use?
さんによる
And will it come off again when I NEED it to?!
さんによる
コメントを追加
On my iPhone 6s, the top of the screen popped off when I dropped it, I turned it into at&t and they fixed it for 100& but I dropped it again and it broke again, I cried. My mom is done paying for my phone. Do ou know what I could do
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
That happened to me and boo just buy a new phone.
さんによる
コメントを追加
回答を追加する
Bub さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 6
今までの合計 71,156
