メインコンテンツにスキップ
2015年1月発売。XPS 13ラップトップは”見た目はボーダレスなインフィニティディスプレイ”を搭載し、タッチスクリーンへアップグレード可能な、MacBook Airと対抗するべく開発されました。
Upgrading the SSD, will it be compatible?
I scrolled through the comments and saw that the required ssd m2 for this laptop (xps 13 2015) would be 80mm NOT the 60mm ones.
So will http://www.amazon.com/Samsung-850-EVO-3-...
Fit in perfectly and run perfectly with the bios and stuff?
My new to upgrading ssds. Would it be as simple as plug and play?
It is currently running ( samsung pm851 with 128gb)
Thanks in advance
Sheldon
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
1件のコメント
さんによる
コメントを追加
1 件の回答
ベストアンサー
Yes. I just completed this exact upgrade just minutes ago. I got an external M2SATA to SATA adapter/enclosure at the same time I bought the new SSD (http://amazon.com/gp/product/B00SM0M5QC?... - enclosure instructions were horrible). I put the new SSD in the adapter and connected it to one of the laptop USB ports using a SATA to USB adapter I already had (http://www.microcenter.com/product/35793...). I wanted to retain the GPT partitioning with the support partitions and found the Samsung Data Migration software inadequate to do this (at least one partition was not recognized). I also looked at EaseUS ToDo, which also did not appear to have the needed capabilities. MiniTools Partition Wizard Free Edition (http://www.majorgeeks.com/files/details/...) performed the migration well. I did a disk clone keeping all partition sizes the same, moving the last, ~7GB, partition to the end of the new drive and then resizing the C:\ drive to consume all of the new space. The clone process took ~1 hour, with a reboot needed to clone the boot partition; I ended up with a 457 GB C:\ drive.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Can I just insert it then and clean install Windows from a bootable usb? I don't have a sata to usb convertor.. And I don't need those filss
さんによる
I would certainly think so; I can't imagine a scenario in which it would not.
さんによる
コメントを追加
回答を追加する
Yong Sheldon さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 24
今までの合計 6,362
